On a brand new MiniBook, I can’t get the built-in keyboard working in Linux (tried Ubuntu 18.04, 20.04 and the latest stable Debian release).
The keyboard works fine in the bios, bootloader and during linux installation process, but when booting the installed operating system, the keyboard is for some reason disabled.
Using an external keyboard works, and curiously, switching to a text-only console, the built-in keyboard works.
I guess there’s some strange mapping issue with Xorg somewhere, but I haven’t been able to figure it out.
Does anyone have a similar experience or solution?
Yes, I am pretty sure we are having the same problem. I found the cause of the problem, and a workaround solution:
It seems the subsystem that reports whether the laptop is in tablet mode or not always reports that it is in tablet mode. As a consequence, libinput will disable input events from the keyboard. I don’t know whether this is a driver issue or a hardware issue with our specific laptops, since I can’t find many references to the problem.
Either way, it is possible to fix it by enabling a “quirks” option in libinput. First create the directory “/etc/libinput”, and then create a file in that directory named “local-overrides.quirks”:
Reboot the computer, or just restart Xorg, and keyboard input is working
Hope it helps.
If someone from Chuwi could chime in, it would be nice. Obviously this is a bit of a workaround, and the tablet mode switch should be working better. Some additional info: While monitoring the tablet mode switch hardware with the evemu-record program, there is never any events happening from the tablet mode switch, so maybe it is indeed stuck in hardware for some reason, or simply not working.
is there a native solution instead of using a workaround?
On my minibook package there is a checkbox on “windows” configuration and a blank box on “Linux” configuration. So, I think there will be a Linux configuration
I also had the same issue with my keyboard not working when I updated my Linux Mint 20.
I had just done a clean install of Mint 20 which came with the 5.4.0-26-generic kernel, and the keyboard worked exactly as it should. After updates, a new kernel (5.4.0-47-generic) was installed. When I booted up using the newer kernel, the keyboard did not work once the login screen is reached. I was able to login by opening the Accessibility option and using the on-screen keyboard, but I still could not get the built-in keyboard to work after login.
I have reverted to the older kernel for now, but I would like to see a supported solution from Chuwi. In the meantime, I will try the libinput quirks workaround posted above and report back.
UPDATE: following the libinput quirks work around options worked! I am now able to use the built-in keyboard at login with the 5.4.0-47-generic kernel.
I realise this is an old thread, but in case anyone still has this problem of the keyboard not working in Linux, try upgrading your kernel. There was a bug causing this issue, but it has been fixed:
