Keyboard Repair Kit
The minibook x n150 keyboard z is creaking.
Do you have a repair kit??
It could be a small particle that makes the noise.
You can search Google for a tutorial.
When I open the keycap, the part called hinge under the keycap is defective… This part is a mini-book, so it doesn’t fit the size of a regular laptop…
You go to the Chuwi website and write to support.
Thank you.
We dont have repair kit. You can buy a replace if there is stock or send to repair if its still under warranty
I don’t have a repair center in Korea
I bought it on AliExpress, but it’s cumbersome to send it by courier and get it back.
So, I want to buy parts if I can buy them
