Laptop had got stuck on logo and it’s continuously loading only and it didn’t getting turn off or on just only loading
Windows is R.I.P.
I’d suggest making the windows installer on other windows PC and then booting in it on the laptop. Then just select repair and keep files instead clean install and you should be fine (in theory).
Give me your serial number and i can send you the windows and drivers
