Linux Mint - No Left Speaker - Chuwi Corebook X 7430U - AMD Renoir Radeon High Definition Audio - Conexant SN6180
2.1 Serial number: JCoBXpIY1H250703606
2.2 Bought at www.chuwi.com,
2.3 Bought the 25th of November 2025
2.4 Problem:
Hello Chuwi!
Like the title says, my left speaker is not working on Linux Mint.
I’ve found this forum which somehow points to a software related issue for those laptops on Linux: https://www.reddit.com/r/linuxmint/comm … peaker_in/
Something like pins not properly connected… I’m a noob
Here is the system information:
benoit@chuwi:~$ inxi -Fxz
System:
  Kernel: 6.14.0-37-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
  Desktop: Cinnamon v: 6.6.6 Distro: Linux Mint 22.3 Zena
    base: Ubuntu 24.04 noble
Machine:
  Type: Laptop System: CHUWI Innovation And (ShenZhen) product: CoreBook X
    v: N/A serial: <superuser required>
  Mobo: N/A model: N/A serial: <superuser required> UEFI: American
    Megatrends LLC. v: AB525_V00.01_0002 date: 07/04/2025
Battery:
  ID-1: BAT0 charge: 46.2 Wh (100.0%) condition: 46.2/46.2 Wh (100.0%)
    volts: 13.1 min: N/A model: AMD Battery Li-ion Real Battery status: full
  Device-1: apple_mfi_fastcharge_1-5 model: N/A charge: N/A status: N/A
CPU:
  Info: 6-core model: AMD Ryzen 5 7430U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB L3: 8 MiB
  Speed (MHz): avg: 1303 high: 1690 min/max: 400/4056 boost: enabled cores:
    1: 1469 2: 1113 3: 1113 4: 1113 5: 1690 6: 1397 7: 1113 8: 1113 9: 1611
    10: 1397 11: 1397 12: 1113 bogomips: 50305
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
  Device-1: AMD Lucienne vendor: Emdoor Digital driver: amdgpu v: kernel
    arch: GCN-5 bus-ID: 03:00.0 temp: 44.0 C
  Device-2: HYGD-XH--241023 USB Camera driver: uvcvideo type: USB
    bus-ID: 3-3:2
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
    loaded: amdgpu unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
    resolution: 2160x1440~60Hz
  API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa
    v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4 direct-render: yes renderer: AMD
    Radeon Graphics (radeonsi renoir ACO DRM 3.61 6.14.0-37-generic)
  API: Vulkan v: 1.3.275 drivers: N/A surfaces: xcb,xlib devices: 2
Audio:
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 03:00.1
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
    bus-ID: 03:00.5
  Device-3: AMD Family 17h/19h HD Audio vendor: Emdoor Digital
    driver: snd_hda_intel v: kernel bus-ID: 03:00.6
  API: ALSA v: k6.14.0-37-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
Network:
  Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network
    driver: rtw89_8852be v: kernel port: f000 bus-ID: 01:00.0
  IF: wlp1s0 state: up mac: <filter>
  IF-ID-1: enx82045f233693 state: up speed: N/A duplex: N/A mac: <filter>
Bluetooth:
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB
    bus-ID: 3-4.3:4
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
    lmp-v: 12
Drives:
  Local Storage: total: 476.94 GiB used: 42.97 GiB (9.0%)
  ID-1: /dev/nvme0n1 vendor: AirDisk model: 512GB SSD size: 476.94 GiB
    temp: 40.9 C
Partition:
  ID-1: / size: 467.89 GiB used: 42.96 GiB (9.2%) fs: ext4 dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 48.5 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 16 GiB note: est. available: 15 GiB used: 6.18 GiB (41.2%)
  Processes: 411 Uptime: 1h 16m Init: systemd target: graphical (5)
  Packages: 2027 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
More infos:
benoit@chuwi:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: Generic [HD-Audio Generic], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: Generic [HD-Audio Generic], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 1: Generic_1 [HD-Audio Generic], device 0: SN6180 Analog [SN6180 Analog]
  Subdevices: 1/1
In the System settings > Sounds, testing left and right speaker outputs on the same right speaker - or possibly the left speaker test is on the sub woofer should this one be placed on the right side on the laptop…
The sound output is good via BT airpods and the audio jack. In Windows, all is fine. So it can not be a physical problem.
I’ve tested things with alsa-tools-gui and hdajackretask to see if I could connect the left speaker with a unconnected pins. Here are the results:
There are 4 speakers on the laptop, 2 right ones and 2 left ones. On each side, there is a front and a back speaker.
Here are the woking Pin ID (the ones that accepts Internal speaker, Internal speaker LFE and Internal speaker Back) ;
  • 0x16
  • 0x17 - Only one active without any changes
  • 0x1d
  • 0x26
  • If they are all overridden and disconnected I have no sound at all.
  • If I activate any of them and leave the other deactivated, and set the to either internal speaker, Internal speaker LFE or Internal speaker Back, there is no differences. Only the 2 right speaker (front and back) get activated.
  • If I activated them all and choose either internal speaker, Internal speaker LFE or Internal speaker Back, still only the 2 right speaker (front and back) get activated.
At this point, I don’t know what else to try.
If anyone from the Chuwi support team could help me, that’d be awesome.
Many thanks in advance for your time.
Best,
Benoit
This is a user forum; no one from Chuwi monitors it.
Check the forum; I don’t think there’s support for Linux Mint.
Hi Bruzan,
Thanks for your reply.
If any user knows a solution to this, I’ll gladly read it.
I know the Corebook has been designed for Windows only. But he who shall not ask, certainly won’t get any answer !
And who knows, maybe this will help others.
To everyone who is still looking for a solution to this,
Here it is!
Please follow the last post of this solution on Github:
We all need to give a massive thanks to Daniil Merezhko (avrora13377) for being to one who saved us, Linux users, with our Chuwi Laptops. Noone but him has had the nerve to find a solution for us.
Enjoy your Stereo Sound.
