Nifu
1
My laptop uBOOK DESKTOP-V4VAMUT (Product ID: 00356-02222-35651-AAOE) , the microfine is not working after updating software.
can your provide the steps, using factory reset for the microphone reset or any steps to fix microphone not working.
Regards,
If u use Windows 11 it will kill your mic because off privacy. So check in your settings if windows did not mute the mic there.
System >Sound
Input > Volume.
You see a mic. Icon and a sound bar that’s moving on sound. If the mic. Icon has a \ It’s off, and you have to reactivate it by clicking on the icon.
