Hi everyone, I have a stupid questions:
none of the function keys F1/f2/… work, did I touch something or hw problem?
I tried reset but nothing changed.
PS PC Is new.
That is odd…do the controls work when you hold down the Fn key and press the F-key, like for dimming the monitor or volume controls?
By default the function keys work as normal F1 to F12 keys and in combination with the FN key as special keys. That can be reversed in the BIOS settings. When reversed the function keys work as special keys and in combination with FN key as F1 to F12 keys.
I think this is a handy feature. Personally I use the special keys more often than the function keys.
Jaap
You guys made me feel stupid but I owe you a beer, it works thanks ![]()
Huzzah!
Yeah, no worries! It’s normal on most compact laptops and it takes time to ger used to if coming from PC so don’t feel bad. ![]()
