Minibook Battery
Hello:
I need advice to buy a battery that is compatible with a minibook Type CWI526 12V- 2A, I understand that the model was already discontinued by CHUWI and that they do not sell spare parts, but will it be possible that I can get some compatible spare part?
Thank you very much for your help.
I have the Minibook X so can’t confirm it myself for sure, but there are some options available on aliexpress and probably ebay, for example: https://www.aliexpress.com/item/1005001338934817.html
If nobody else can confirm it, you might want to open your laptop and see if the battery looks identical.
