Minibook X (10.8in, N5100, W11 21H2) UCM-UCSI ACPI Device error
Hi all,
Windows device manager shows “Windows has stopped this device because it has reported problems (Code 43).”
I tried to update the driver, but no update available and the best drivers are already installed.
No video out to external monitor or microSD card not recognized.
Strangely, if I disabled the device, the video out seemed to work.
Also, when disabled, microSD card appeared as d: drive.
However, only one of them worked at a time.
Does anyone have the same issue?
It would be nice to fix the driver, though.
Could you tell me how to fix it?
Thanks a lot!
tell me your serial number so i will be able to locate the original files. Maybe uninstall and install again when i give you the drivers?
It is ZMinBXHY1H220100466. Thanks!
Windows ZW-JX-108-S105JWR120-JCB0B-071-D
Drivers:
(MiniBook x win11驱动)
