Windows decided to not be friendly with me and had bluescreened my MiniBook after updating. Silly me didn’t back up the drivers for it beforehand and now after re-installing Windows, all works but the touchscreen (accelerometer(?) is a bit wonky, but i can live with it). I’ve emailed Aftersales support who may have misunderstood what I was asking.
Currently there are 2 unknown devices in Device Manager, and i believe one of them might be the touchscreen. I’ve already tried installing the HID touch screen drivers on both to no avail.
Looking to get some help here if anyone with a MiniBook can provide some drivers. Really just looking for the touchscreen drivers, but an entire package would be nice. If anything is needed (i.e hardware id, etc.) I can provide it.
It is logical that, after a clean installation of Windows, the system does not recognize the drivers of non-Intel devices. This happens on any device of any brand.We must then install the drivers that Windows has not been able to install.To do this, after downloading the drivers of our tablet or laptop model and unzipping them into a device storage folder, disable Windows protection for the installation of unsigned drivers.To deactivate this protection, press start, restart with the shitf key pressed, and restart now. When you restart, an advanced reset screen will open in which you must press 7 or F7 to deactivate the protection and it will restart normally.
It is time to go to the device manager, by clicking on the start button with the right mouse button and in the menu choose device manager, and see in the device tree the drivers that are not correctly installed. (they have a yellow triangle).You have to click on each of them with the right button, driver properties, update driver. On the next screen, choose the option below “search for driver software on the computer”. On the next screen “choose from a list of available drivers on the computer” and on the next one you must click on the use disk button; The browser will open and select the folder where you have unzipped the downloaded drivers, checking the option to search in subfolders.The system will install the device driver. You have to repeat this process with each of the devices with a yellow triangle or unknown device. Keep in mind that if you restart, the protection will be activated again, so you must activate it again when you have to install a driver.
I do not have the MiniBook to extract the drivers or the file, but we will quote @Management to provide us with the link
Thanks for the reply, Aftersales had provided me with an image. @Management please do provide drivers or an image, since clearly some of us are the brightest of people (Me) lol.
