Hi everyone!
I got inspired by linux-thinkpad-speaker-improvements, so I decided to replicate this with my Chuwi Minibook X (N100), but using AutoEQ target curves rather than Dolby’s magic. This actually made my laptop speakers waaaay better, and they’re nowhere near as tinny as they were before!
I documented the bulk of my work here, including how to replicate the measurements:
But tl;dr:
- Install EasyEffects
- Add the Convolver EQ effect with the WAV file linked in the repo (don’t forget to also apply the Impulse file after importing it)
- Audio should sound immediately better by now, but to make it even better, add the Bass Enhancer plugin to add bass harmonics
Your laptop should now sound vastly better than most Windows laptops, and even almost as good as actual Macbooks themselves!
Note that this works by reducing unwanted peak frequencies, so the overall volume of the audio is quite a bit lower. If you don’t like how quiet these speakers are, then this will only make it worse, but the audio quality trade-off is worth it imo.
