Minibook X Keyboard backlight turns off after a few seconds (solved)
Please tell me, is it possible to share files for this serial number?
ZMinBXHY4H240202077
I have a different BIOS version:
DNN20A V2.03 x64 from 12/28/2023
And the archive contains version:
DNN20 V2.19
The file is also valid for your computer, is inside the batches i published in the above post. try and see if it works.
@ChuwiSpainSupport, Hello, I have a FreeBook, but really don’t like the auto backlight off either.
My serial number is ZFreeBCY6H231100221. It is a chuwi freebook 2023 with i3-1215u and 12gb ram.
Is there any way to also get a modified BIOS for my device?
Thanks in advance.
I’m not sure. I have the same new revision with slow memory and other differences from older MiniBook X N100:
@Goldi please open a new thread for that so it does not mix with Minibook X and will see if Tech can help
@kaznelson i asked tech and they told me its valid for your serial number, try it .
Hello, can I have same patch for ZminBXHY3H230702976?
@sleeply4cat i will ask if possible as yours is not onto those serial numbers
I also have dnn20a 2.03, the program you sent writes “Error: ROM file ROMID is not compatible with existing BIOS ROMID”
@tverka is your laptop inside the batch serial numbers i gave? because if not it wont be compatible.
Unfortunately no, I just tried it, thanks
give me your SN , im writting the rest to see if tech can make another patch
I also get the same message.
The keyboard backlight does not turn on on my minibook either.
My serial number is ZMinBXHY4H240201329 and I need the same patch.
@nifl i will ask too
Tech told me will try to make another patch but not sure, it will take a while.
Hello. Can you ask the same fixed BIOS for me?
Serial of my minibook is ZminBXHY4H231002193.
It would also be useful to obtain the sources of the latest BIOS version. I’m a developer and this would help the community
@paul_official the patch i sent previouslly is ok for you, is inside the batch numbers for that one
Hello. can you fix the keyboard backlight? ZMinBXHY4H240201634
@V1mba i will add yours to the list pending for tech
Thank you. Using all methods I am getting an error message “Error: ROM file ROMID is not compatible with existing BIOS ROMID.”
My current BIOS is:
DNN20A V2.03, 12/28/2023|
SMBIOS Version 3.5
Are you please able to advise?
