When I turn on the backlight for the keyboard on my Minibook, it turns off after a few seconds. I need to press a key to turn it back on again. Is there a way to disable this? It’s inconvenient that I need to mash my keyboard in the dark to turn the light back on and find whatever key I need. Thank you.
It’s the default behavior. At the moment there is software provide on CHuwi devices to control and have option always ON.
This is usually a third-party app that some other manufactures are used to provide but this is not the case.
Ну и где это программное обеспечение , купил Chuwi FreeBook в 2024 г. такая же беда , знал бы не покупал это говно . Не пойму зачем это вообще , что это за подсветка если она гаснет .
Помогите.
Thanks @ChuwiESnotactive.
Just to be clear, I don’t want it always on. If I turn it on, it should stay on. If I turn it off, it should stay off.
ZMinBXHY4H231003026.
ZFreeBCY6H231101049 Chuwi FreeBook 2024
ZFreeBCY6H231101049 Chuwi FreeBook 2024, гаснет подсветка
ZFreeBCY6H231101049 Chuwi FreeBook 2024, гаснет подсветка клавиатуры
Tech already sent this to the person who needs to do the patch. It would be ready in a few days i hope. So you can solve this
I observed the behavior on Dell laptop. The keyboard backlight will go off after a few second of inactivity also. But as soon as you touch the touchpad, the keyboard will light up. I hope Chuwi will copy this behavior.
- Restart your Minibook and enter the BIOS setup: The specific key to enter BIOS varies between manufacturers, typically F2, F10, or Del. Look for a message during boot-up telling you which key to press.
@sgpearse This is the patch. For Minibook X
The patch you see in this topic is valid for Batch Serial Numbers:
ZMinBXHY4H231000001-ZMinBXHY4H231000500
ZMinBXHY5H231000001-ZMinBXHY5H231001000
ZMinBXHY6H231000001-ZMinBXHY6H231000500
ZMinBXHY3H231001001-ZMinBXHY3H231002000
ZMinBXHY4H231001501-ZMinBXHY4H231002500
ZMinBXHY4H231002501-ZMinBXHY4H231003500
ZMinBXHY4H240201301-ZMinBXHY4H240203000
ZMinBXHY4H240200001-ZMinBXHY4H240201300
@mmb your laptop is not minibook but a Freebook ?
MiniBook X keyboard always on-off ZMinBXHY4H231002501-ZMinBXHY4H231003500.rar (7.8 MB)
Добрый день. Помогите устранить данную проблему с клавиатурой на моем ноутбуке Mini Book X N100, серийный номер HY4H230901203.
Очень не удобно, что она все время гаснет и нет возможности выбирать вариант с постоянно горящими клавишами и выключенными.
@i will ask tech to see if they can make another patch for your serial number
@Marusia Tech told me this patch would be valid for you too:
Спасибо. Вы очень помогли. Клавиатура стала работать корректно, то что и хотела.
Может быть вы и доработаете кодеки для звуковой карты, так как звук у ноутбука из коробки слабый, но сторонние программы хорошо его усиливают. Но было бы хорошо, сделать новый кодек, который усилит звук динамиков.
Большое спасибо.
i will see if tech can do it. Thank you
I have the same issue. The backlight is functional but turns off too soon, which makes it difficult to use in low light.
Is it possible to have a patch as above that will work for my serial?
ZMinBXHY4H240202843
i will ask @microprosopus
@microprosopus I asked Tech and they told me it could be valid also for your computer. You can look the above messages and download the files i sent.
