ZMinBXHY4H240701712
bought on Aliexpress last September
All of a sudden, my Minibook stopped working. The screen doesn’t light up after waking it up. Even a hard shutdown doesn’t help. All the LEDs behave correctly, and the keyboard backlight is operational. From what I can tell, the OS doesn’t boot — I can’t see the Minibook in the list of devices on my router.
Tried to boot it with an external display attached - no success
It could be a hard drive or other component issue.
You can try entering the BIOS, pressing ESC or DEL, and turning it on.
You can contact support through the Chuwi website.
If you need the OS and Drivers, you can download from here i checked and it works
