The Minibook X 2023 I have works as follows:
Off: no leds lit
Off and power supply connected: led beside the usb port lit
On and power supply not connected: led beside the power button lit
It takes some 10 seconds to push the power button to force the laptop to switch off.
If my display would not work I would first check if the power led is lit. If so, push the power button for at least 10 seconds to force the laptop off. (Been there, done that)
After that I would connect an external display and see if that would work to be able to check or reset settings.
Finally, if leds and external displays wouldn’t work I’d either send it for repair or bring it to a recycling station.
i note same situation “black screen” when i try to wake up the MiniBook X N5100
when it is under "over load of memory or processor use
same when MS Update in back yard
Solution is to wait and let time to the MiniBook X to achieve complete is wake-up
some time it take over 30 minutes
this is less significative with the MiniBook X N100
Hi all,
Sorry for the late reply, I’ve tried all the suggestions and none of them worked.
It seems to be an hardware issue because the BIOS doesn’t even boot or display something either in the panel or external display.
I’m gonna send the device for repair.
