MiniBookX does not boot
Hello
My minibookX does not start correctly
ZMinBXHY2H230200972
Buy it on Ali Express last month.
I want to create a bootable device (usb) to repair it.
Thanks in advance.
AB
It won’t boot properly: what is it ?
You can watch a tutorial and download Windows from the Microsoft website.
I did a Windows upgrade. After that my network card just disappeared. So I’ve tried to downgrade. And now my screen is black when i boot. So I want to restore the computer.
You can search for a tutorial to start in: Safe Mode
Ok. I’ll try that n let you know.
drivers
Good afternoon! My minibook does not boot properly. Dark screen, when you turn it off and then turn it on it starts to boot properly. What to do. Please send drivers for MiniBookX ZMinBXHY4H230900150``
The first thing is to determine if it’s a software or hardware issue.
You can download the drivers from the Chuwi website, support, downloads.
Thanks for the answer! how to determine the problem? are the drivers for all serial numbers the same? These are suitable (Minibook x 10.51 (5100) drivers)
You can contact Chuwi support
