Miniboox x wont start
My serial number = ZMinBXHY2H230100093
Hello friends can you help me…my chuwi minibook x wont start…and it says UEFI V2.70 in black screen…
Im try to check in bios
Boot option just NVME
Thank you
You may be having problems with your startup disk.
In the BIOS, I see you have an option to boot from USB.
You can try booting from a Linux USB drive.
You can find a tutorial on Google.
You can download the operating system and drivers from the Chuwi website, in the “Support” and “Downloads” sections.
I tried to update to Windows 11, but during the partition selection process, the partitions on the laptop didn’t appear…
That’s what I mentioned above: you might have problems with the startup disk.
Okay, thanks friend
So, in this case, it means my disk is faulty, right?
I’ll try a different disk to see if it’s recognized by my laptop
Not necessarily. During a Windows update, the boot partition was corrupted. If possible, boot Windows from a USB disk and follows the installation until there’s a choice to repair the existing Windows system. That should automatically fix the boot process, so a UEFI shell is not presented on boot.
