MiniBook x N5100 Does not Boot
Serial number: ZMinBXHY3H220500564
I received the minibook as a gift three years ago.
The minibook was fully installed. I don’t have any documentation that would show the Windows registration number. However, since Windows was already installed on the system, I’m hoping you can tell me the number.
I need to create a USB boot drive, and I need the software and registration numbers for that.
With best regards
Axel Buckl
Hello
What problem occurred that prevented it from starting?
I checked and you can download everything from here
Thank you,
but apparently this “MiniBook X” isn’t supported there. Entering the serial number doesn’t do anything. The system doesn’t even tell me that it doesn’t have any data for it.
But if Chuwi no longer supports its own MiniBook, where can I get the OS and device drivers? Does anyone have any ideas?
I find it strange that you can’t see the files.
Yes, I can see the files.
Oh, sorry,
I, the idiot, forgot that I could scroll down the page. Now I can see the downloads, too.
Thank you very much.
No problem.
What problem are you having that you want to reinstall ?
The MiniBook belongs to my sister. I don’t know what she did. When I start the MiniBook, I only get to a prompt. Operating system commands like ls, ll, dir, or similar are useless. An external boot didn’t produce any results either.
For this reason, I would like to boot with the appropriate operating system, format the disk, and reinstall the correct operating system and drivers.
If the operating system was working fine before this problem occurred,
You can watch a tutorial to repair the startup and not lose the data on the laptop.
The commands to repair the startup from the command prompt are:
bootrec /fixmbr
bootrec /fixboot
bootrec /scanos
bootrec /rebuildbcd
Ah, okay. Thank you very much.
I’ll test this as soon as my sister is back.
Then I’ll get back to you, either way.
