Minibook X N100 - Powerbank recommendations
Hello all,
I”ve got a Minbook X N100 which I really love, been using it for over a year. One thing I don’t love is the battery life, and I’ve made my peace with that. I’m a bit out date on my depth when it comes to portable powerbanks. Does anyone have a recommendation for a good one that they use? Or what spec I should research when looking for them online?
Thanks in advance!
Fantastic, I can’t believe I missed that. Is the powerbank still working well for you?
Yes it does.
Have fun with the little minibook!
Cheers,
Jaap
Try Anker 20,000 mAh designed for laptops. It’s what I am using, even with my MacBook.
