- Serial number : ZZMinBXHY4H240702981
- Buy AliExpress
- 11/11 Buy - 11/16 Get
- After receiving the product, I applied the tablet mode (360 degree folding) after booting to check the operation status, but in other words, the screen does not rotate. After that, I downloaded all of the os/drivers provided by Windows 10/11/chuwi and reinstalled and reset more than 30 times to resolve this symptom. Still, the g sensor does not work properly as if it is broken. I will solve the driver problem somehow, but it is no longer possible to handle it with the official homepage. I hope you can find a solution
It’s a silly question, but is rotation lock off in Windows 11?
We may be talking about the same thing, but I’m pre-coffee, so I figured I’d check here…once you’re in Tablet mode, check the Settings > Display for the rotation lock slider…it’s grayed out in the screenshot here because I took the shot in laptop mode, but once I open computer to tablet mode, then it becomes an adjustable slider. That’s slid to off, and it’s still not adjusting the screen when the tablet is turned?
You’re saying the same thing
The screen won’t rotate even if it’s unlocked and active
Ok, that’s a bummer. Sorry for my confusion! Maybe Chuwi will have specific drivers for your machine that will help. I hope they do, because I love my minibook.
Send it back, and have a replace, you are still on the warranty period. Its probably that the sensor is not working properly.As you installed everything
Is there any way to do as or warranty repair in Korea? Or should I talk to the Aliexpress seller I bought? Aliexpress says that only refund/return is possible. If so, how should I get the warranty repair?
If you bought in Aliexpress, and want to return, you need to contact the seller in Aliexpress, they will help you do that.
same situation here, but i fixed it by opening device manager, sensors and ticking off option that disables the device in power saving mode
Actually it should be also possible to fix by just charging the chuwi ![]()
Hope that help someone
thx for the tip
I just tried your suggestion on my Chuwi Freebook N150, but it doesn’t work. Windows 11 doesn’t enter tablet mode when I fold the screen. The driver is installed correctly, but rotation is locked and the button is disabled. Customer support ignored the issue, so I think I’ll return the device. What a shame!
