MiniBook x n150 bios trouble
SN ZMinBXIY4H251100474
bought it from aliexpress 20th of january 2026
I just try to update bios and accidentally bricked my chuwi((( can some one give me bios file or help to find it to install for repair. Now minibook dont work but battery indicator is work when it charrge and keyboard backlight and power indicator is light for a second when a push the button
UPD: I contacted support, they will help me soon, but I think I will need a BIOS firmware .bin file. Does anyone have one? My bios FM25W128
How did you try to update, or what procedure did you follow?
i found utility at russian 4pda and try to update with it. utility is a some files and one .bat file that start process in cmd
The BIOS shouldn’t be updated like the operating system.
Updating the BIOS requires some technical knowledge that I don’t think you have.
I believe the Chuwi motherboard doesn’t have the option to reinstall the BIOS from a USB drive:
I think if the computer won’t turn on, you’ve corrupted the BIOS.
To reconfigure the BIOS, you need a specific program or tool.
You need to ask Chuwi support: service@chuwi.com
I wrote to support, thanks. I know that it’s bo not update like OS. I only want bios file and my friend will help me update it with prog tool
I should probably add that the computer simply won’t start at the moment and I plan to fix this by Flashing the BIOS chip using a programmer Wizardprog If I’m not mistaken. For the firmware I need .bin The firmware file for the motherboard that is in minibook x n150.
Can some1 help to find .bin file?
And maybe some1 know what motherboard is this?
