Minibook X N150 - Linux (Fedora KDE) screen rotation fixes (with automatic rotation)
I recently bought a Chuwi MiniBook X N150 and discovered that Linux has no out-of-the-box support for autorotation on this device and rotation in login screen. In fact, it often causes more problems, especially when using Wayland.
To fix this, I created a GitHub repository with detailed instructions and a shell script that automates the process. I’m currently using Fedora KDE Spin, but the solution should work for most GRUB-based KDE distributions.
If you run into any issues, feel free to open an issue on GitHub.
That should be quite helpful for those using KDE based distros. Well done.
