Hello, I need help. My Core Box Pro only starts in BIOS mode. I try to reinstall the Windows 10 operating system with a bootable USB flash drive but do not finish the process and continues to start in BIOS mode.
How far along does it get with the Windows install?
Need more details, you need to describe exactly what is happening. Did it even boot from USB to start the Windows install?
How far along does It get with the windows install? Run all the phases
of the installation very well until it reaches the last phase:
Finishing Up. The process stops and the following message appears:
Installation Canceled
Windows could not prepare the computer to boost into the next phase of
installation. To install windows, restart the installation.
The error began after a routine Windows update in Windows 11.
From the USB the installation of the operating system began but fails to reach the last phase. I need help please.
Mi spiace amico, questi pc hanno tanti problemi, persone che dopo tre mesi di vita non gli si accende piu il pc.
Tanto fumo e niente arrosto.
