Ok, i have modified the file that you have passed so that it adapts to your resolution, to see if it goes better: 2.2 KB file on MEGA
Thanks! ill try it out
Hi! Ive tried it, its better i guess, Now I only have a small deadzone in the right but the tracking is inaccurate. Here’s the vid
Okey, try with this updated file: 2.2 KB file on MEGA
In this version, i add sensor 60-63 and reorder driver memory. I think maybe this fix the problem… try it and tell me.
Hi it’s still the same though
Here’s the vid *sorry for the portrait video
Also does this help in any way?
try this. 2.2 KB file on MEGA
Sorry, it is very difficult to program a driver without having the HW in hand …
I understand and I’m very thankful of your help!! Would sharing teamviewer make it easier for you?
Hi! no improvement though
The red part is the deadzone but the title bar can be accessed by touch
try with this. 2.2 KB file on MEGA.
If not work… Tell me and i will speak with you by PM.
Ok thank you so much!!
Hi still not working but I kinda found something out, Where can I PM you?
I have the exact same problem. Any working CFG file?
Sadly none yet, Chuwi is not very helpful too, they just told me that my screen is defective and I should buy a new one lol. Its clearly a firmware/cfg error which they provided me with a link but it clearly doesn’t work, literally the touch on the screen doesn’t work anymore so I had to reflash it with the bad cfg.
XD la verdad es que no entiendo nada. Saludos
Saludos a todos los que forman parte de esta comunidad
HAS ANYONE BEEN RESOLVED?
Hello everyone,
I have the same problem, it seems happen to lots of people as I saw. Is someone have the right config file please ?
Many thanks.
Hi, no fix as far as i know. Im still waiting too for someone who might be able to have a fix on this issue.
How do I install a Cfg file?
