Need replacement touchpad for Minibook X N100
2.1-You must post the Serial number of your product: ZMinBXHY4H231002533
2.2- Where did you buy it (Aliexpress, www.chuwi.com, etcc): chuwi2019 on eBay
2.3- When did you buy it: May 2024
2.4 Where are you from: United States
2.4- Explain in detail your problem:
My Minibook X N100 touchpad is broken. It works for just a few seconds and then the cursor flies all over the place and freezes up. Where can I order a replacement?
