powerbank ► USB booster cable to DC ► CHUWI Herobook Air ?
Hi, I’m trying to have computer while long black out/etc. Will the set up below work without any issues? See attached. Pls advise/suggest/etc. Thank you…
powerbank
(output 5V/2A) (a)
USB Power Booster Cable
(input 5V to output 12V/2-3A) (b)
CHUWI Herobook Air (c) but without built-in battery
(input DC 12V/2A (d))
References:
(a)
https://shopee.ph/Yoobao-M4-Mini-10000mAh-Cute-Small-Dual-Input-Dual-Output-Portable-MINI-Power-Bank-i.66396718.7647428668?sp_atk=494736d4-539c-40a7-95ed-6d41ea8625e3&xptdk=494736d4-539c-40a7-95ed-6d41ea8625e3
(b)
https://shopee.ph/product/92372854/9680749032/
(c)
https://shopee.ph/CHUWI-Herobook-Air-Windows-10-11-Mini-Portable-touch-screen-Laptop-11.6-Inch-1366x768-IPS-Screen-Lpddr4x-4GB-128GB-SSD-Intel-Celeron-Processor-N4020-Dual-Core-Support-i.316135415.13118821869?sp_atk=90e553b7-061d-4fc1-8fff-505a2ed1d4a8&xptdk=90e553b7-061d-4fc1-8fff-505a2ed1d4a8
(d)
this is the screenshot of what I wanna happen/etc
Hello
Not sure which is the power of Original Supply. Your Powerbank will not delivery enough power I believe.
you have 5V 2A, Power = Voltage x Current, so you have 10W delivery.
When you use Step Up to 12V, you should still keep the 10W,
10W = 12 x Current , in the end with this setup you will delivery only 0,8A of current on Laptop, which I believe it-s not enough to charge it.
Original charger delivers 12V at 2A, so 24W. In order for powerbank to provide enough power you would need a supply of 5V at 4.8A.
Better setup would be to get a powerbank with USB-C output that delivers at least 2A at 12V, and use a converter from USB-C to the plug of Herobook charger.
Regards
