Problem bios please help
The problem is that after reinstalling Windows, an error appears (you can see it in the screenshot), and the system keeps rebooting. When you disable the energy‑efficient cores, it starts up. Could you please send the latest BIOS version so I can flash it, or suggest a solution to the problem?
Model: Chuwi CoreBook XPro 2024 15.6 i5-12450H
Serial number: JCoBXpIY1H240801992
Where did you download Windows from ?
Before reinstalling Windows, did you save a backup of the drivers ?
You installed the drivers after installing Windows.
There is an error notification at the bottom of the screen; have you tried looking it up on Google?
