Product ID not working at support page
I’m writing because I’m trying to download drivers from the support page of chuwi but I’m getting the following message:
*“Database Working Un-normal now, Please contact local retails and distributor for Service”
I have bought it via AliExpress.
Do you know which can be the problem?
@ChuwiESnotactive, could you help me?
Thank you very much.
You’re not entering the correct ID. Double-check the letters and numbers; you must have made a mistake somewhere. Especially check the O’s and 0’s, as this can be confusing.
Tu ne rentres pas le bon ID. Vérifie bien les lettres et chiffres tu a dû forcément te tromper quelques par. Vérifie surtout les O et les 0 celà peut porter a confusion.
Hi Iro,
I have tried several combinations of 0’s and O’s; l’s, I’s and 1’s; but they don’t work.
I think the correct format is SUbox0IZxHxxxxxxxxx (where the ‘x’ are numbers).
Regards
Write to service@chuwi.com
I have written to support@chuwi.com and they asked me the serial number a week ago. I’ll wait a few and if they don’t answer, I’ll try with service@chuwi.com.
Thank you very much
They have just anwered me. They updated the database and now it works.
Thank you very much and regards.
