Replace the battery minibook
hello guys … long time aint been here
i have also problom like every alse with the battery
is there any guide how to replace
it will much appreciate
tanks
A true guide isn’t (yet?) avalible, but it’s quite easy.
  1. Remove the screws from the bottom side of the Minibook and remove the bottom cover.
  2. Disconnect the battery from the main board.
  3. Remove all screws that secures the battery .
  4. carefuly remove the battery from the Minibook. Note that two thin (audio) wires aren’t damaged.
  5. Insert the new battery.
  6. secure the battery, secure the thin audio cable, connect the battery and screw the bottom cover onto the Minibook.
Replacing the battery is very straight forward. You will need a small Philips screwdriver and a pair of tweezers and that’s it. (and obviously a replacement battery)
Very helpful instructions. Thank you.
Now, I just need to source for the exact new battery - mine is bulging/expanding. I am not sure how long I can still use the device - before finding replacement?
give me your exact model and serial number, i will ask if we have in stock natteries
