The Hi10 X apparently won’t charge directly off of a standard USB-C charger port. It requires the bulky 45W charger. Is there any way to get it to charge from the same USB-C that will charge a Macbook Pro or a standard USB-C multiport charger?
If Chuwi is stating that this is USB port and it can be used for charging with 12V than it HAS to support PD otherwise it’s not USB port (in terms of standards) but something that looks like UBS port… Normal USB port, without PD can handle up to 5V. I also think this is a bummer as you have to carry out additional charger just for that tablet - even if it supposed to support USB charging. I just bought it few days ago - and when I realised that this is not USB port - I requested return and refund straight away. Will see how it will be handled.
Bonjour je rencontre actuellement le meme problème. Cela signifie que je doit me procurer un adaptateur min de 45W pour réussir a changé ma tablette ?
Merci
I just don’t want to carry multiple chargers any more. So I bought this from Aliexpress:
And obviously a USB-C adapter tip.
It’s working well for me. Obviously I have to carry an additional cable - but only one actual power supply.
(I’m using this for the actual charger now:
It’s probably not the best pd charger because it only goes up to 12v 1.5a. But the pins fold down so it fits in my pocket without causeing discomfort.)
