SATA connector cable for Larkbox x 2023
As you know, the Larkbox X has a SATA port. But no one knew which connector would fit that port. Chuwi doesn’t sell it or provide information. I got the information from another community and bought a connector cable. It works well.
If you want to buy sata connector, buy the product from the link below. This is a cable used for other mini pc but it works 100% with larkbox x too.
https://www.aliexpress.com/item/1005006345912206.html
Thank you for this information.
I am sure many users would be glad to know
Can i install an 3.5 HDD?? Your link tells me is sold out… im.in germany
Hi, I’ve been looking for the exact connector for the Larkbox for a while without success, but the link you share is for a sold out product. Do you know what other device it corresponds to so I can look for it from another seller on Aliexpress? Regards.
3.5 hdd and 5.25 odd cannot be used in this port.
Sorry, I only know that seller.
Oh, why not? Does it need 12V? I have an external 3.5 HDD disc over usb. I want connect it via sata… i need a solutuon
I think it’s probably because of 12v.
do you know other shop to buy this connector? the shop from the link you posted is not working any more
i made a picture and searched in taobao to see if i could find it. I will keep you posted. As aliexpress does not give any resut by picture
On my Larkbox x 2023, the space is not equipped. I only have the solder points.
It must be the new version
Hi. Any news on this topic? I did some research and, afaik, it was a connector that also korean mini pc manufacturer used to expand to sata ssds. This means that this connector might be more Available in their market. I hope this helps someone.
Please inform us when you find an appropriate product @ChuwiSpainSupport
Hello, I am also looking for a cable to connect an SSD to a Chuwi larkbox X. Could someone please post a current link to purchase through aliexpress?
