The Micro SD controller is unstable. It is periodically disabled. Me
ssage-code 10
This is a well-known problem and there is no effective solution other than replacing the CPU.
no effective solution ??
really ??
I just buy a second used Hi12 table , and find this bug .
SD card fail on win10 . but android use SD card ok …
This is a processor malfunction. You can switch the sd card operation in the bios, install drivers from other tablets, but these are all temporary solutions.
I use “Z83-4-Driver-Fix_SD_card_cannot_be_seen.zip” , and win10 can see 32G sd card , android also , but I try many 32G FAT32 SD card , only find 1 32G tf can work , other exFat 256G win10 can use , but android 5.1 not
SD cards over 64GB officially is not supported.
To use exFat / NTFS in android you need to get root and install patch chuwi-android-fs-1.0.4-install.zip - Google Drive
