HI all,
how to make the € sign on the chuwi UbookPro keyboard ? , as the Alt +0128 does not work for chuwi , and tired to copy paste the stored €
Bring up the emoji keyboard (Winkey + . ), select the Ω symbol on top, then the $ symbol on the bottom, scroll down and select the €. After that you can quick select it in the most recently used (clock) symbol.
, Thanks , at last a little bit quicker than looking for notepad where I stored € , but at least Chuwi could sacrify …but at least Chuwi could sacrify some key or combination to make it easy
Thanks it works now the way you described
