Tablet reboots unexpectedly
I have a problem with new HiPad Plus. It’s generally working fine, but reboots unexpectedly once/twice a day. I would like to somehow test if this is a hardware or software issue and if hardware I will send it for repair. Are there any tests available? Is anyone else experiencing the same issue?
Jacek
Can you identify the restart with a certain process or application? Is it during a game?
In this case, you can reboot your system.
I Purchased a Chuwi HiPad Plus Serial - HiPadPQ128G21031292 - and it also reboots randomly - when browsing the internet or even when on home screen. This is annoying and almost making it not usable.
Encontrou uma solução, amigo? Estou com um HiPad Pro com o mesmo problema.
Mine has now just done it and won’t stop only used 30% of storage and just had YouTube up at work and it just randomly stopped looked at it and it restarted just thought what ever got my video back on and 5 mins later it restarts every 5-10mins wether your on it or just home screen
