Hi everyone
I bought a Chuwi ubook one month ago… It used to work fine but suddently, yesterday it ran out of battery and there is no way to charge it. Once I connect the device to the charger the red light turns on for three seconds, then stops. And after three seconds again the same loop: three seconds red and stops. The device is not charging …
Do you guys have or can suggest any solution? Needless to say, this is quite annoying after just a month using the tablet…
Thanks!
