I think the battery voltage is below the minimum level for the system to turn on. Try to put the charger on for 24/48 hours to see if, after this time, the charger LED lights up.
Battery is okay and charged. I was using the PC previously and the battery is full, then suddenly everything become dark and charging has no respond. Unplug battery also not working.
Any other possible idea what could be the problem?
Maybe you could take the laptop to a repair shop. So they can give you a clue. Before repairing. IF its the battery and need to be changed you can write my colleagues and see if they have a battery available to sell you. Sometimes we do not have stock sometimes we have.
Select your zone up right side(Europe/USA etcc)
Menu-Explore -Contact us- Aftersales Service
-Fill the form(is important to fill this and not write a simple email)
Write Maria, at the beginning (so my colleagues know i send you)
-Dont forget to write
your Serial Number
Where are you from
When did you buy it(warranty purpose)/Where did you buy it
My colleagues will answer you telling if we have stock or not and
shipping prices and cost.
They answer normally in 48/72h, if not, write me and i will check in case it went to Spam.
If possible in English language (they dont understand any other language)
