I just recently bought a ubook pro for my wife so she can use on her studies. After a week, she started complaining of a keyboard problem which I can only describe as “Intermittent Keyboard Jumping”.
The problem seems to be that there are times while she is typing, the cursor would jump from the it’s original position and goes somewhere else. By the time she notices, she had already typed stuff and would have to do corrections. Since it’s intermittent we can’t find a pattern, it results to frustration.
I initially thought the touchpad might be too sensitive to slight touch – it doesn’t seem to be the case. We disabled the touchpad and tested to see if the problem persists – and it’s still there.
Has anyone experienced this issue also?
Thanks a lot in advance!
Regards,
Joseph
