Can someone tell which pd adapter should I buy, that will definitely work with ubook pro?
I bought the ZMI (HA832) PD adapter based on several reviews. I like the fact that it also has 2 additional USB-A fast charging ports (QC3.0) along with the 45W USB Type-C PD port. I can verify that this PD adapter works fine with the Ubook Pro and does also deliver fast charging on the USB-A ports. I had no problems charging the Ubook Pro. At some stores, you can get a 1.5M USB type-C to type-C cable sold along with the adapter. I would recommend getting this cable or another one that can support at least 45W charging.
