Hello! My HiPen 7 stopped working and i tried several times to reboot it and etc.
When i tried to fix the issue, i stumbled across this:Touchscreen and pen deadzone FINALLY SOLVED
And after that, my screen went crazy like in the video.
Displays incorrectly.
How can i fix this issue? Please help me. Thanks.
Because of the drivers, is possible we not the adecuate one. Please uninstall them,and see if it will work
If not give me your serial number and i send you Windows and Drivers to reinstall again
I rolled back my windows prior fixing anything. It didn’t help plus tutorial didn’t install any drivers.
ZUbkXPCW1H230601476
After this tutorial my screen went crazy. I used some CFG file and after that my screen started looking wrong
Recovery DID NOT help. I need a correct configuration for a goodix app
I need a correct CFG files like in the tutorial I’ve sent you in the beginning.
This tutorial wasn’t compatible with my computer and after that the screen went crazy m
I need a correct cfg file configuration for a goodix app for my computer because recovery and reinstalling the system WON’T work
