Ubook Xpro difficult to startup and USB C suddenly not working
1.UBook XPro 2023 13” 8GB 512GB i5
2, Order on Oct14, 2023
3, Store CHUWI Global-Flagship Store
4. Serial No: ZUbkXPCW1H230800939
My Ubook is getting more and more longer to startup. Try many time to press the startbutton and after many times it works. Now I don’t dare to shut down. only Putting the notebook in sleep mode and the power input is always on.
Another issue I have is that the USB C port suddenly is not working.
Appreciate any advice to help resolve my issues.
It could be a hardware problem.
You can download the software from the Chuwi website, under support, downloads.
