URGENT: Secure Boot 2023 Certificate Migration Issue on GeminiBook Plus & XPro (N100)
Hi everyone and Chuwi Technical Staff,
I am reaching out to the community and Chuwi support regarding a critical security compliance issue affecting the GeminiBook Plus (Alder Lake-N100) and GeminiBook XPro (12th Gen N100) models.
We currently manage a professional deployment of these devices. While testing them for compliance with modern Windows security standards, we discovered a significant flaw regarding the Secure Boot certificate chain that requires an urgent firmware update from Chuwi.
The Problem: Stuck on the Expiring 2011 Secure Boot CA
As many of you may know, Microsoft is actively phasing out the old Microsoft Third-Party UEFI CA 2011 and transitioning to the new 2023 CA. Because the 2011 certificates are expiring in 2026, systems that do not update to the 2023 certificates will enter a degraded Secure Boot state.
Usually, Windows pushes this update automatically to the UEFI firmware. However, detailed diagnostics on multiple GeminiBook N100 units reveal that the current Chuwi firmware prevents this automatic migration.
Our technical findings:
  • Secure Boot is enabled and active.
  • The UEFI variables (PK, KEK, db, and dbx) are present but do not expose any SignatureType GUIDs.
  • The firmware does not expose X.509 certificates to Windows, which is required for the OS to push the new keys.
  • The registry keys used by Windows to track the 2023 certificate rollout exist, but no status value (such as UEFICA2023Status) is ever created.
  • Windows cannot detect the 2023 Secure Boot certificate chain on these devices.
In short: The GeminiBook Plus and XPro are permanently stuck on the expiring 2011 Secure Boot CA because the firmware does not accept the automatic key update from Windows.
The Impact
Since we are now in 2026 and the 2011 certificates are reaching the end of their lifespan, this is no longer a future warning but a current, active issue. The consequences are severe for anyone using these laptops in a professional, educational, or regulated environment:
  1. Compliance Failure: The devices will fail modern Zero Trust, Intune, or MDM security baseline checks.
  2. Vulnerability: We are unable to apply future Secure Boot dbx updates (revocation lists), leaving the devices vulnerable to known bootkits.
  3. OS Updates: Future versions of Windows 11 may block installation or feature updates on systems lacking updated Secure Boot trust anchors.
The Expected Solution from Chuwi
To resolve this, relying on Windows Update is not enough. We urgently need Chuwi to release an updated BIOS/Firmware for the GeminiBook Plus and GeminiBook XPro (N100 series).
This BIOS update must natively include the Microsoft 2023 Secure Boot certificate chain (updated PK, KEK, db, and dbx databases) so that these devices can remain functional and secure.
Questions for the Community & Support:
  • @Chuwi Support: Is there a BIOS update currently in development for these models to address the 2023 CA migration? If so, when can we expect the release?
  • @Community: Has anyone else run into Secure Boot compliance issues with their N100 GeminiBooks? Has anyone received a beta or custom BIOS file from support that fixes this?
Thank you for your time and assistance. I look forward to your feedback and a swift resolution from the Chuwi engineering team.
I think you’re asking in the wrong place.
You can contact customer service.
I reached out to Chuwi support in 2026 February, March, May and July, but I have not received any response so far. I hope this message and the attention on this forum will help bring a solution!
Whose certificate is it ?
Maybe that’s why Chuwi didn’t reply to you.
Reply / Update: RESOLVED - Secure Boot 2023 Migration Successful
Hi everyone,
A quick update on my original post: I am happy to report that this issue has been resolved and a manual BIOS/Firmware update from Chuwi is actually not required after all.
After further investigation and allowing Windows to fully run its update and reboot cycles, it turns out that Windows Update successfully pushed the new Microsoft 2023 Secure Boot certificates to the UEFI in the background. The GeminiBook’s firmware is indeed capable of accepting the automatic key update from the OS.
If you want to verify that your N100 GeminiBooks are secure and compliant for the 2026 deadline, you can easily check this yourself:
1. Check the Windows Registry
Open PowerShell or Command Prompt and check the servicing status. If the migration was successful, you will see UEFICA2023Status : Updated under this path:
HKLM:\SYSTEM\CurrentControlSet\Control\SecureBoot\Servicing
2. Verify the active BIOS database via PowerShell
You can directly read the active Secure Boot database in the firmware by running PowerShell as an Administrator and executing this command:
PowerShell
[System.Text.Encoding]::ASCII.GetString((Get-SecureBootUEFI db).bytes) -match 'Windows UEFI CA 2023'
The command should return True, confirming the 2023 certificate is physically loaded in the BIOS.
In short: as long as your devices are fully updated via Windows Update, the transition happens automatically and the devices will remain compliant. No need to replace them!
I hope this helps anyone else managing these devices.
