Any body know where i can make purchases battery cover for my chuwi hipad pro 10.8?
We normally have repleacement parts.
If you want it:
Go to you www.chuwi.com ,
Select your zone up right side(Europe/USA etcc)
Menu-Explore -Contact us- Aftersales Service
-Fill the form(is important to fill this and not write a simple email)
-Dont forget to write your Serial Number /Where are you from/When did
you buy it(warranty purpose)/Where did you buy it
My colleagues will answer you telling if we have stock or not and
shipping prices and cost. -
They answer normally in 48/72h, if not, write me and i will check in case it went to Spam.
If possible in English language (they dont understand any other language)
Hipad pro 10.8 Battery cover
Serial number JHipadPKY1220402967
Thank you, when you say battery cover you mean the back part of the tablet that covers all?
Yes it is, the back part of tablets… do you have replacement?
I had the same issue with my Chuwi Hipad Pro 10.8. I ended up finding a battery cover on AliExpress, and it worked out fine. If you don’t see what you need there, try contacting Chuwi’s support—they were pretty helpful when I had questions.
