sorry I cant help you
This worked! It is hard to find the section to enable the wireless , i believe it was under the “northbridge” settings or one of the bridges and there are 2 wireless options not just one. Set them to “Enabled” and your done.
Ho lo stesso problema da qualche giorno.
La scheda di rete WIFI è sparita ma funziona il Bluetooth.
Nel Bios non trovo nessuna opzione nascosta.
Come risolvere?
Ricaricando il bios?
Si possono avere i file BIOS per il Lapbook Pro?
sn: LapQ256G419120566
Grazie
on rzbox when you have proble with the card: the solution is:
unpluged the power adaptor, wait 5 min and conected again.
maybe chuwi need provided a beter solution. this problem is recurrent every some month
