15.6" 4K UHD Display/Intel i5/i7 Processor/USB-C/55WH Battery/PD2.0 Fast Charging Need new Power brick
where can I get a new brick for this laptop
I used to charge thru USB-c = now no longer working
need advice please
Can you tell me you model and serial number please? You described everything except that​:full_moon_with_face::full_moon_with_face:
CHUWI AEROBOOK
chuwi aepluso256g20052660
Ok, can you please send me apicture of the charger? because that is what you need right?
i dont have the old one - it was lost in my move
see pictures attached
thanks
We have the charger in stock,
Please do this:
You need to Go to www.chuwi.com
Select your zone up corner right side (select Global)
Menu-Explore -Contact us- Aftersales Service
-Fill the form aftersales
-Dont forget to write INSIDE in the message:
0- Write that you need a new charger for your laptop and you were told there is stock.
1-Serial Number /
2-Where are you from, if possible tell the address complete.
My colleague will send you instructions on how to pay and so.
*They answer in 48h
