Anyone know how to fix minibook 8 from waking up randomly from sleep?
Seems like my minibook 8 have issue with randomly waking from sleep without any touching.
Tried to change a few power options but doesn’t work.
The only thing that it work is putting the computer in hibernate mode
I am experiencing exactly same problem.
So my workaround for this is
  • disable the computer from going to sleep
  • disable the harddisk from turning off. Power Options -> Hard Disk -> turn off harddisk after x
  • instead of going to sleep, I changed my power button to hibernate instead
Hibernate seems to work 100% of the time.
I think unless Chuwi decide to release a new firmware, this will always be an issue
