Is it possible to configure Wake on Wi-Fi from sleep mode on a device (specifically, wireless, i.e., via the built-in Wi-Fi adapter)?
In my case, Wake on Magic Packet and Wake on Pattern Match are enabled in the device settings for the Wi-Fi adapter (Realtek 8852BE…) (there is no “Power Management” tab in the device settings). WOL is enabled in the BIOS.
In sleep mode, the device is permanently registered with the router (i.e., the adapter is working), but WOL doesn’t work.
The Wi-Fi adapter is not listed in the output of the “powercfg /devicequery wake_armed” command.
Is there a solution to this problem?
N.B. WOL works fine through any of the Ethernet ports.
I don’t know if our AuBox 8745HS wifi can WoWLAN, but you can make it simpler: just go to UEFI > Advanced > Auto Power On and set it to “Power On“. Then you just can turn your AuBox on with a smart plug like Tapo P100.
