Hello, i decided to downgrade from windows 11 to windows 10 after getting this laptop and im experiencing issues with the audio, there seems to be no audio driver installed, these are some images for extra help if you need:
as you can see there is no audio driver in the sounds category in device manager
i need the audio drivers for this laptop model, please does anyone have them so i can download?
Give me the exact Model and the Serial Number so i can provide to you the right ones.
you can download official image in here https://support.chuwi.com/
I am not sure if this is the correct model, but on the back it says ‘lap book s15 n2 256gb’, also is a FCC id the same as the serial number?, because i cant find any other code that is like a serial number
Make a picture of what is written in the back please. Will be easier.
Jesus, this is actually funny, the laptop is not ours, in the label you can see this https://www.fusion5store.com/, you bought it another store, another brand. But they have similar names as our old old Lapbook
I searched the web and you need to contact there; eve@fusion5store.com
Ah, Thats why i was confused when i couldnt find this model anywhere on the chuwi website, thanks Man😂
is ok it can happen to anyone, two names, now i know we have a brand with our same names
I know this is not the same company but I am having the same issues with the lapbook Fusion5, no audio, and the website they give no longer works, was just wondering if you managed to fix the issue and if so can you send me a link to the driver used as im stuck with a laptop with no sound and no support from the makers
@Aram1732
