Battery meter always show 100% until dead
hello, i am on unlocked bios, 8100y europe version,
and i cannot flash the normal ec file and this patched ec file.
when charger unplugged, battery always show 100% until dead,
if i am charge to 90%, battery meter is normal.
from device manager, uninstall “microsoft acpi compliant control method battery” still not fix it.
i think my battery meter work normal, until i flashed bios from management to fix fan issue.
“(PS: If you think the minibook’s fan sounds too loud, you can try brushing the BIOS to improve it)”
What should I do ? and i want turn off the fan too.
thank you.
Contact service@chuwi.com , they will give you instructions how to fix it.
I’m a user of M3 version.
I had the same symptoms.
However, drain the battery completely, then charge it 100%.
Repeat 6 to 7 times, the current battery indicator starts normally.
Also, problems with fan can be helpful by looking at the links below.
all my problem is solved now.
i am successfully flash my EC.
my flashdisk is fs7
type
cd fs7:
and than
eFuitX64 /u “ec.bin” /faildelay
i dont really know if eFuitX64.efi file, is executable in dos :sweat_smile:
anyone can copy paste this to Startup.nsh file, if flash not work successfully.
flash is work successfully if show proccess of flashing… on blue colour screen.
# ITE Tech. Inc.
# UEFI Shell IT8987E eFlash Update
echo
fs0:
if exist Startup.nsh then
goto Flash
endif
fs1:
goto FLash
endif
fs2:
goto FLash
endif
fs3:
goto FLash
endif
fs4:
goto FLash
endif
fs5:
goto FLash
endif
fs6:
goto FLash
endif
fs7:
goto FLash
endif
fs8:
goto FLash
endif
fs9:
goto FLash
else
goto end
endif
:FLash
eFuitX64 /u "ec.bin" /faildelay
:end
