Hi
I have BIOS version 2.18.1263
The setting is here: Chipset -> South Cluster Configuration -> Miscellaneous Configuration -> State After G3
I set this to “S0 State” but the system does not boot when power is applied, I still have to press the power button to make it boot. Setting it to “Last State” gives the same result.
Can anyone confirm this behaviour?
Is there a solution to make the system boot as soon as power is applied?
For information, I am running Debian Buster.
TABEM ESTOU COM O MESMO PROBLEMA
The same problem. Who found solution already?
There’s a hardware “solution”: LarkBox: Automatic boot on power? - #8 by justauser
