I hesitate to buy this mini PC, I need to have windows and a life cd under linux.
Anyone know if we can boot from the SD card.
A big thank-you.
A big thank-you.
In theory, you can, as with a USB drive. Only in the BIOS will you need to switch the boot method.
Thank you, i have take one
After test i’m go back to this tread
I receive my mini-pc, booting on SD card work perfectly.
Is this some build feature that doesn’t support booting from flash drives? It certainly sounds strange, but sometimes the most incredible assumptions turn out to be true.
