Is there a way to boot from a USB flash drive in the new Larkbox?
I think you can get to the boot order in the bios by pressing DEL when it first turns on.
There’s probably a boot menu shortcut key, but I’m not sure what it is.
Thanks, but the Boot menu doesn’t list the USB ports as a boot option.
Try it with a udb drive plugged in ?
